Is this a file I can create? or download and put in the correct folder to make it work??
You will get more search results if you enter album name too.
Also note that, except for GraceNote, there are some limitations with other sources:http://getmusicbee.com/forum/index.php?topic=8756.0
Any updates on gracenote yet??
i have made contact with gracenote and they have indicated the license needed renewal which i have just done. They also indicated they will increase the quota so we will see how that goes.Hopefully it will be back online soon.
