Author Topic: pops clicks and pics  (Read 10564 times)
mrmoustache
Oh well updated to RC2a, moved google up and down in the list in tags(2), no dice.
For the albums where the album art search works, there's never anything for google, it's always displaying "no match". In fact google stopped working for me a long time ago, I was just using discogs or fanart.
discogs is removed from RC2a so perhaps you are not using that version (you can check using help/about). In any case i wont spend any time looking at this as google has been working fine with the 2.3 series and verifed by forum members
@mrmoustache:
You might want to completely uninstall MB and then re-install it. Might be your old settings file that creates problems.
mrmoustache
@steven: No, I was using the RC2, I noticed discogs was gone.
Installed 2.3 final and still the same, I'm going to uninstall and reinstall as redwing suggested. Thank you guys for your help.
