Author Topic: Artwork View scrolling for Touchscreen monitor  (Read 6797 times)
J3Man
Artwork view does not work with touch - other views do. Would like artwork view to be touch compatible as well.
J3Man
Hi Steven Thanks for the effort but Im getting this error - is there something I am doing wrong?MusicBee v2.3.5146.15655 (Win6.2), 2 Feb 2014 9:04:
System.TypeInitializationException: The type initializer for '#=qCrg6epFL2tI7eik5Azbzuw==' threw an exception. ---> System.ApplicationException: Unable to load 'C:\Users\Brian\Desktop\MBee-SKINS\MB 2,3\MusicBee_Exe_Patched (1)\bass.dll'
   at #=qWR_Xav4tH8GplKY4JNPYNBy1e7WOK0AStsROrPiu3rc=.#=qnAGgkaQ80M4fk8ZeBy9jyOTotndlO3CRxSpAaV4UTH4=(String #=qu05DqVj0JNpTOrHghuxORw==)
   at #=qCrg6epFL2tI7eik5Azbzuw==..cctor()
   at #=qCrg6epFL2tI7eik5Azbzuw==.#=q9p58Lgr1rclMSJrVE3_yTA==()
   at #=qutFjMvLj05_aX2NNM_aJPfLEZm4DvxEKkrkegfx9y_4=.#=qmTbDpaStyG2374yjCQJG4w==(IntPtr #=qwT4GeoIAzLZFHLwH4DTnWA==, ISynchronizeInvoke #=qLXhw4o5iiLCTgocvyYr1Lg==, Boolean #=qMfMBECq3AS3QjLLpBy5NGg==, List`1 #=qgTa7uABfvG0PPqgI1ZC4RQ==)
   at #=q3DqYvoOoe_NPlMpriHRUwP4xLIAzLFM1dUFjU1gMbY8=.#=qzz7QKM5h3WFLXV_lKNucizIa8CNxxGG2KZpf4ZGpJQo=(IntPtr #=qMpH9rP3DJVs0ZRvVtkmh7Q==)
   at #=qm2NT6c8QJUr5G3YOh4x3rGL18OnIkZKnIh0DwWhGT7c=..ctor(IList`1 #=qTdB_us2f2vmhQfchOg110g==)
   at #=qm2NT6c8QJUr5G3YOh4x3rGL18OnIkZKnIh0DwWhGT7c=.#=qb2omesk7C56Ibz3LlFFHEuoJ5eehYrO9l_8k9Jg5E7c=.OnStartup(StartupEventArgs #=qoNRMU1B$6RYB2RCDKWKDgw==)
J3Man
Steven, it did not fix problem - not a big deal really but would be nice.
will you run a debug version?
also with a touchscreen, what action are you using and do you have to do it directly on the scrollbar?
and lastly, does it work with the left navigator panel when the scroll bar is displayed there?
Last Edit: February 02, 2014, 06:35:26 PM by Steven
J3Man
First, if I try to scroll within artwork panel with finger nothing happens-use the scroll button on the right works fine. As said scrolling with finger in other views works fine. Would probably be able to run debug version at some point if needed.
so its definitely working with the left navigator panel?
and if you touch directly on the scrollbar rather than in the panel does that work?
the other views in the main panel are implemented in a completely different way to the artwork view
J3Man
J3Man
Sorry no go. The left scroll bar, the column browser (on left) works. Just still no artwork scrolling. EDIT- should probably mention that touch scrolling does not work with lyrics panel docked to the right.
Last Edit: February 02, 2014, 07:42:48 PM by J3Man
J3Man
Sorry about that, I meant the scrollbar on right side works, all else listed should be sane.
i dont think you have understood what the "left navigator" is. I wont be spending any more time on this
J3Man
Didn't mean to offend, if I did. Yes the touch works in left navigator - was just trying to explain what works and what doesnt
bitseq
Touch screen control of the Artwork view would be amazing, I have musicbee on a touch screen by my hifi but not being able to scroll in the artwork view is a little frustrating, any chance you could look into this again Steven?
Cheers
