Author Topic: Skin-adaptive toolbar button coloring option  (Read 24075 times)
  • MB Version: 3.6.9255 P
Setting an alpha on the new colour would only change the overall colour but wouldnt make any difference otherwise
so even with the alpha I wouldn't be able to achieve a semi-transparent look like this?
bugger  :(
thats different to what was done with redwing's request but is easy enough to do by making use of the alpha setting for the colour override
SimonBRT
this is a really great little addition btw.  small details like this really add up.
thats done for the next v2.3 update
Thanks Steven, but it's sorta, not quite, working the the right way
Its applying the alpha from <element id="Panel.CommandIconOverride" fg="180,147,81,148" />to the entire icon area, not just the visible parts of the icon.
IMHO, for such a minor tweak, lets revert to the previous "no alpha" version, and not worry about it.
Thanks again for taking the time to have a go at it  :)
Even without alpha value, some skins display icon background in a different way from the majority. Also some bitmap skins have a problem with this setting. A few examples:
you need to make sure the RGB components are the same colour as the panel header
don't know about the others, but the slightly darker area around the icon in Metro Touch is deliberate. It's set by bg2 in:
<element id="Panel.CommandButtonOverride" bg="Ground" bg2="Ground-3" fg="TextGround" />
Oh OK, will give that a go.
i have made the algorithm more sophisticated and probably is now what you were expecting. You can tint using any colour now - as long as there is an alpha component it will use this approach and when there is no alpha component it uses the way redwing requested
these are the result of some unfortunate fg choices for the header control element where the colours are similar/same as that panel background.
The skin developer can easily correct that or use the new element if they want
this has the amended colouring algorithm
WOW! Thank you very much. Working perfectly  :)
Now, I just need to create some time to modify my skins  ;)
Not a big deal. Users can always disable the setting.
this has the amended colouring algorithm:
Just another big thank you for implementing this.  :)
Really like the way it gives an "antique" look to my coloured icons when using Bee78
Bellissimo!!
