Hello,
yes, this is different to "Edit" from the context menu.
Edit works only for songs, not for albums and artists.
I can only select multiple songs and select edit.
Check means that MusicBee analyzes the files and then shows me a table with errors.
First column: the song title.
Then you have a column telling the user what is wrong (missing tags, missing cover, missing song text).
This way I can check a specific artist (or album) and MusicBee tells me where I have to correct my data.
I know the "Tagging Tools" from the menu.
But this idea is different:
- user can check specific songs/albuns/artists
- user sees what is wrong with a specific song.
Greeitngs
OLLI
