Author Topic: Google Play Music Access  (Read 116728 times)
@ScuddZero
Thanks for video.
Also when I login, it first says login failed but works the second time you click ok.
This is normal, the same for me. I spent too much time trying to resolve this and leaved this as is because it works anyway,
Obviously plugin can't emulate Music Manager for downloading (and hence for playback too). Did you use Music Manager for uploading (just uploading is sufficient) one or more tracks? If you did, then I have 1 idea what might go wrong on your PC.
ScuddZero
Yes uploaded a few thousand tracks using the manager program.
I'll post modified version of plugin soon.
@ScuddZero
http://www.mediafire.com/download/49x9fd9s55jcai4/mb_GooglePlayMusic_2014-01-20.zip
Upgrade plugin and go to Edit> Prefs> Plugins to configure plugin. Try to change Music Manger ID in plugin settings (no restart required) and try to play online tracks after that.
ScuddZero
Updated the plugin and it works using mm:A4:17:31:7A:13:83
All the others just threw up the same error.
Does the plugin have the ability to play All Access music or just user uploaded tracks.?
Thanks for your help.
Last Edit: January 21, 2014, 04:49:43 AM by ScuddZero
Glad that the problem is resolved. Suggest that you have more than 1 network card.
Haven't tried it, but I'm doubtful that All Access music will be played/downloaded.
froschfinger
Hey there,
I am glad you are constantly working on this and try to get us Google Music access to MusicBee ;). However, even your new version does not really pan out. For the first time, I am able to retrieve what looks like a complete list of artists/albums/track etc. Once I try to play any song I get an error message that the song cannot be played or is no valid audio file. Restarting or changing the ID does not help. However, since the latest version I am getting a 'uncaught exception in the application' error or something like that telling me that there is an error in the DragDrop registration, something to do with .NET Framework. Is that error related to the plugin? I didn't have it beforehand ;).
Best
froschfinger
Hi, insufficient info for me. Screenshots could help.
froschfinger
Hey there,
I try to make it work - here are two screenshots, plus I include the full error message from that clipped window. Unfortunately the messages are in German, but most thinks are stated in English.
Thanks for looking into it!
Screens:
https://preview.cubby.com/pl/ScreenClip.png/_24400642ff5549849638070839b2466c
https://preview.cubby.com/pl/ScreenClip+%5b1%5d.png/_f92ab3b024d141f4abfe1145feb02e22
Error message in full:
************** Ausnahmetext **************
System.InvalidOperationException: Fehler bei der DragDrop-Registrierung ---> System.Threading.ThreadStateException: Für den aktuellen Thread muss der STA-Modus (Single Thread Apartment) festgelegt werden, bevor OLE-Aufrufe ausgeführt werden können. Stellen Sie sicher, dass die Hauptfunktion mit STAThreadAttribute gekennzeichnet ist.
   bei System.Windows.Forms.Control.SetAcceptDrops(Boolean accept)
   --- Ende der internen Ausnahmestapelüberwachung ---
   bei System.Windows.Forms.Control.OnHandleCreated(EventArgs e)
   bei System.Windows.Forms.Control.WmCreate(Message& m)
   bei System.Windows.Forms.Control.WndProc(Message& m)
   bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
    Assembly-Version: 4.0.0.0.
    Win32-Version: 4.0.30319.34003 built by: FX45W81RTMGDR.
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll.
MusicBee
    Assembly-Version: 2.3.5100.22821.
    Win32-Version: 2.3.5100.22821.
    CodeBase: file:///D:/audio/MusicBee/MusicBee.exe.
    Win32-Version: 4.0.30319.33440 built by: FX45W81RTMREL.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll.
System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll.
System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll.
Microsoft.VisualBasic
    Assembly-Version: 10.0.0.0.
    Win32-Version: 12.0.20806.33440 built by: FX45W81RTMREL.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll.
System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll.
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll.
System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll.
System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll.
MusicBeeIPod
    Assembly-Version: 1.6.0.0.
    Win32-Version: 1.6.0.0.
    CodeBase: file:///D:/audio/MusicBee/MusicBeeIPod.DLL.
Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll.
mb_GooglePlayMusic
    Assembly-Version: 4.2.5136.35070.
    Win32-Version: 4.2.0.0.
    CodeBase: file:///D:/audio/MusicBee/Plugins/mb_GooglePlayMusic.dll.
Microsoft.GeneratedCode
    Assembly-Version: 1.0.0.0.
mb_TheaterModePlugin
    Win32-Version: 1.0.0.0.
    CodeBase: file:///D:/audio/MusicBee/Plugins/mb_TheaterModePlugin.dll.
GoogleMusicAPI
    Assembly-Version: 4.2.5134.17362.
    CodeBase: file:///D:/audio/MusicBee/Plugins/GoogleMusicAPI.DLL.
Newtonsoft.Json
    Assembly-Version: 4.5.0.0.
    Win32-Version: 5.0.6.16206.
    CodeBase: file:///D:/audio/MusicBee/Plugins/Newtonsoft.Json.DLL.
System.Numerics
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll.
System.ComponentModel.DataAnnotations
    Win32-Version: 4.0.30319.33440.
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.DataAnnotations/v4.0_4.0.0.0__31bf3856ad364e35/System.ComponentModel.DataAnnotations.dll.
System.Runtime.Serialization
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll.
System.Xml.Linq
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll.
System.Data
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll.
System.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.resources.dll.
mscorlib.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/mscorlib.resources/v4.0_4.0.0.0_de_b77a5c561934e089/mscorlib.resources.dll.
System.Windows.Forms.resources
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll.
@froschfinger
1. As for "no valid audio file" - did you use Music Manager for uploading track(s) on PC running MB?
2. For "uncaught exception in the application" - what do you do when this error happens?
froschfinger
Hi there,
as for 1. yes, I did that, just recently. Just tried to open it up, all fine. Still no playback, even when I try to change the ID in settings...
as for 2. nothing in particular, though I don't always get that message immediately. I just try to play songs from Google Play, and I get that no audio file error message, and sometimes that uncaught exception thingy :(.
1. First of all upgrade MB to latest version (you are using 2.3.5100 now):
http://musicbee.wikia.com/wiki/Latest_Update
2. Try to upload a track which wasn't uploaded earlier with Music Manager: create folder 'temp', add 1 track to it and upload this folder. Then try to play this uploaded track.
3. It seems that unhandled exception is not related to GM plugin, not sure right now.
Last Edit: January 25, 2014, 04:01:14 AM by boroda74
froschfinger
Hi there,
1. Did just that.
2. Have a folder that is being watched, added some tracks there anyway, let the Manager upload them, closed it, started MusicBee. Unfortunately, still no avail; no valid audio file error again, plus when scrolling through the artist list I get the .NET framework error again.
3. I didn't change anything except for the MusicBee and your plugin update, so don't know :/.
Thanks
Froschfinger ;)
1. Try this version of plugin:
http://www.mediafire.com/download/2j7jwhq46h23m8s/mb_GooglePlayMusic_2014-01-26.zip
there are more choices of MM IDs.
2. Can't reproduce this exception. And I don't use drag'n'drop in any of my plugins.
EDIT: Also try to upgrade Music Manger to latest version and upload something with new version.
Last Edit: January 25, 2014, 10:51:44 PM by boroda74
froschfinger
Hey there again,
1. I did just that, no luck, until I disable and re-enabled your plugin. Now I am seemingly able to play back online tracks from my Google Play library.
2. However, after moving through the artist list and clicking stuff, that .NET dragndrop error turns up and crashes MusicBee. I disabled all other plugins to make sure it's nothing there but the core and your plugin. Since you're saying you're not using it I will have to keep investigating, however your plugin seems to work otherwise.
Thank you for your help!
