Author Topic: Movie title field  (Read 17952 times)
I'm working on a TM view for soundtracks. Can you support a TM "field" that can populate "movie title" saved in the user's soundtrack mapping file?
I wish it would populate <album> instead when <movie title> is null, for the TM view to work for non-soundtracks as well.
will it work as you want if it only returns a value if MB is treating the file as a soundtrack?
You mean otherwise it returns null? Then it won't be able to retrieve <album> field for non-soundtrack files.
so you want it to behave like <Album> except if there is a movie title, and if so then use that
i have added "movieOrAlbum" as a supported field
Tried <element type="Field" id="movieOrAlbum">, but it populates nothing both for soundtracks and for non-soundtracks.
Tried again with the new files, but still no luck.
i have re-compiled all the programs and re-uploaded again. Its working fine for me and should work
Yes, now it works. Thanks!
But it returns null when used as child element for next track(Tracks[1]). Can you support that?
there is no obvious reason why it wouldnt work as its the same code as the main field. I dont really have time to dig into it so it will stay unsolved
dont worry - i figured it out but wont post an update just yet
