Author Topic: DarkRED  (Read 187380 times)
digital
Tommy
....... I think the Wavebar option is only available in the flat version, not in the compiled .xmlc
Tommy
That's right for this skin at this moment. Now wave bar option is supported for bitmap skins as well, but the skinner has to implement it.
Tommy
....... where can I get this "Skinner" ?
Tommy
I meant the person who created the skin. If many people make such a request, the skinner would consider it because it's now possible technically.
Tommy
....... please, let me in on the details - How is it possible ?
Thanks to endeavour1934 I've got all the files available .......
Tommy
Tommy
....... thanks a lot for this.
I'll check it out and might be back asking for some advise ........
Tommy
brandonluciano824
This skin is great! Is there any way to make the DARKRED to more of a maroon/burgundy color?
theta_wave
With 6833, the first time I updated in over a month, I noticed that the ratings and fav buttons shifted over to the left of the track playing panel on all DarkRED flat skins, shown in the first image below.  Is there a way to revert back to having these buttons back on the right hand side like before, shown in the second image below (the contrasting color issue was fixed long ago, so please ignore that).
moment
Two years ago I remember I had some skin that was exactly like DarkRED but it was with an option of having a progres bar as a spectrum .
Does anyone know which skin this could be?(I wasn't sure where to post it, this seemed best place)
Gino
  • Teddy Boy
hi to all here
Sorry my simpl question
post #1 ( page 1 )
i have download this Skin > DarkRED ( Great ! )
but ... this other .zip download ( toolbar icons )
> wo sollte es eingefügt werden ?
> where should it be inserted ?
go to see screenshot
Thanks !
In the folder where musicbee.exe is installed, create a sub-folder called "Icons" and unzip them into that folder.
moment
I will answer myself - you need to download the flat xml version. It's also in the first post. Thanks
Gino
  • Teddy Boy
hi to all here
Message to Admin Steven
your Answer ( Thanks again )
is that right ?
did i do it right ?
Sorry for the delay ...
