Author Topic: Four skining questions and a bug  (Read 14042 times)
i have adjusted the centering up 1px for when the progress bar is above, and also for the volume slider i have tweaked the centering which depended on a number of factors if it was 1px too low
http://musicbee.niblseed.com/V2_2/MusicBee_Exe_Patched.zip
endeavour1934
Thanks! It's perfect now  :D
endeavour1934
most accidental forum title eveerrr ::)
;D
BTW, there are still two of the questions unanswered  :P
endeavour1934
By the way, when the player is on the top bar, there seems to be a 1px line below the player, linked to the player bg color. Is there any way to get rid of it?
Try
<element id="ApplicationBackColour" bg="255,0,0" />
Then you will see where the red lines are drawn.
You can adjust their widths by changing values for MainPanelMargin.Left, Right, Top, Bottom and MainPanelSeparatorMargin
Another way is using the same color of background for bg of ApplicationBackColour.
BTW did you see the two posts I added?
