When browsing the Computer node would it be possible to add an option to open the folder in Windows explorer?
I often do this before I organise the files and want to open the folder to see what else is in there than just music files.
I know there is an option to locate a track in Windows explorer (I use it often), but it does not work on folders. Sometimes I relocate the files, but the folder does not get deleted. I then want to check what is left in the folder, but I have to find the folder manually then.
