In the past I sometimes had some troubles with skinning when some elements were not responding to any change in rgb values.
It took me quite some time to find out that there sometimes were duplicate entries in the xml, where the second overruled and disabled the first.
This new feature will show such duplicates. (try it out with your Mondrian 1.2 skin ;-)
The 'size and shape' warning when pasting occurs with some xml's.
I believe the cause is the 'base64 'garbage characters, which forces the xml text 'sometimes to be pasted over more then one column.
This is undesirable, but I wouldn't know of an easy fix, and it doesn't effect the end result.
An important consequence however is that you should always paste a new xml to the right of an existing xml column. If you would paste to a column on the left of an existing column, cells on the right xml column could be overwritten.
The "Do you want to replace..." pop-ups should be gone now.
The previous version had a flaw where not all differences would be displayed.
This new one had some changes to fix that, but it slightly complicated the macro, therefor processing might be slightly slower.
