Author Topic: Send Now Playing song to Playlist  (Read 2248 times)
dondestasmanu
I was thinking it'd be very nice to be able to send the now playing song to a playlist without having to maximize the MusicBee interface and drag the song around. Almost like song ratings, be able via a right click to send the song to an existing (or new) playlist.
Think that'd be feasible ?
-- EDIT: I see that a good way around it is to be in compact mode, select the song, right click, send to, playlist. However, I noticed that if you are trying to multi-select, each assignation happens as you click, so if a song already belongs to a playlist and you still click on it it brings out the prompt of whether to add the duplicate song in the playlist. Also, but this might be too much to ask, it would be awesome to see a check box on the playlist the song already belongs to...
Also, if you send to a new playlist, instead of asking for a playlist name it creates a Playlist (x) entry... it'd be nice to be able to specify the name there and then. Finally, and really finally, if we could use the mouse wheel to scroll down on the list of playlists instead of having to click on the bottom arrow.........
Last Edit: March 08, 2012, 02:19:18 AM by dondestasmanu
