Author Topic: Use of OR command in Search box (An Advance search)  (Read 2677 times)
lnminente
It would be really nice to do a search for "Artist1 OR Artist2" without using the custom search.
I use to do some search and listen only the songs rated with 4 and 5 starts sorted by BPM, so the list is small and it would be great to add more than one artist directly from the Search box.
A very good work with MusicBee. Thanks a lot!
Last Edit: November 28, 2011, 05:36:36 PM by lnminente
