Author Topic: Shuffle playing tracks by album  (Read 176 times)
Max.A
RMB on just added tracks, have the option List → Shuffle list, all songs will be shuffled in random order.
How can I shuffle this list by albums? Forum search didn't get the results
tjinc
The answer to this question will depend upon what you mean by 'just added tracks' (this might be a playlist, tracks just sent to the Playing Tracks panel, a selection of tracks in your library.....)
We would also need to know the view you are currently using.
It would be best if you could post a screenshot of your whole MusicBee window so we can see where you are and what you are referring to and to try and reduce the need for any further back and forth.
