Author Topic: I added an auto playlist but AutoDJ "playlist" dropdown list does not show it  (Read 271 times)
DickRawson
I'm trying to follow this recipe:
[ Create an Auto-Playlist:
Set the source of the Auto-Playlist to your entire library or specific playlists you want to include.
Limit the playlist to a certain number of tracks, perhaps 5-10% of your total library size.
Crucially, set the selection criteria to "least often played" (lowest play count).
Use the Auto-Playlist as your Auto DJ source:
Go to the Auto DJ settings.
Select your newly created Auto-Playlist as the source for Auto DJ.
I created an auto playlist named "rarely played auto"
Yet now, in Auto DJ tab, Source music tracks from: the Playlist menu.
the dropdown list does not show "rarely played auto" (or anything like it) to choose.
What don't I understand?
Dick
if you created the playlist after already opening the auto-dj settings panel then restart MB
