Author Topic: Ipod Classic Sync  (Read 273 times)
ipoduser
I have an Ipod Classic 6th generation.   How the heck do I sync the ipod with MusicBee?  I read the instructions and cannot seem to get anything recommeded to work.  I did search on ipod sync prior to asking this question.  By the way, I was able to move my music from my iPod to a new Itunes instance.  However I cannot get iTunes to work to move music to the iPod.  I have moved the iTunes music to MusicBee.  Now want to sync up iPod.
You say you read the instructions and can't get anything to work. Exactly what instructions did you read? There are a number of threads dealing with syncing to Apple devices, so you should be a little more specific as to what you tried. And when you don't understand the instructions, post your plea for help on that thread.
There's an iphone/ipod driver plugin in the Plugins/Add-ons section. There are also helpful hints in the Tips & Tricks section. Use the MB dedication Google search link in my signature as it's much better than the forums search box.
