Author Topic: Delete playing/upcoming tracks from playlist of origin  (Read 597 times)
dim_union
Hi, the functionality that I'm looking for is, while playing music from a playlist, to be able to delete tracks in the Playing Tracks/Upcoming Tracks panel from said playlist. It looks like when I delete them from there that just removes them from the play history/upcoming tracks.
The best workaround I can see right now is to navigate the context menu to find the song in the playlist, and then delete it from there, but that's three layers deep ('Search' -> 'Locate in Playlist' -> <playlist). I also see that the context menu on the player control has 'Locate Playing Track at Source' as a top level option which is nice, but I will probably not be deleting the actively playing song.
Apologies if the solution is obvious!
Last Edit: June 02, 2025, 04:25:08 PM by dim_union
tjinc
Welcome to the forum dim_union,
This method is not immediately obvious but have a look:
Right-click on track > Include In Playlist > uncheck the playlist you want it removed from.
Any good?
dim_union
Ohhhh yes I did not realize that would work in reverse, makes sense! Thank you!
