Author Topic: Support for Windows shortcut files  (Read 1003 times)
elof
This is a sister request to my "Alt modifier to create a shortcut when dragging a file" request yesterday.
It would be nice if MusicBee support reading ordinary Windows Shortcut links.
Example:
In the Main window, go to Computer | C:\Music\Party tracks\
Currently MusicBee list zero files.  :(
But the folder C:\Music\Party tracks\ is full of shortcuts to mp3 files, so I would like them to be listed.
(the hard part is probably to build a new system to be able to handle shortcut files as shortcuts. I.e. if I press delete on such a file, I want to delete the shortcut, not the mp3 file)
-1
MusicBee isn't, and shouldn't aim to be a file manager.
Pickles7853
You are using the incorrect type of Windows shortcut for the purpose you are asking for.  The more simplistic version (the one you are using) is considered a separate file and thus is ill suited for the task.  Not really surprising though.  The more advanced shortcuts are hardly used anymore these days.  I find many people simply do not know about them.  Very useful in many situations.  The advanced shortcuts are, alternatively, called symbolic links.  Specifically you need what is called a hard link.
Note: You will need an elevated DOS prompt to create them.
Example:
C:\Other folder\AlbumTrack1.mp3
In DOS window:
mklink /H "C:\Music\Party tracks\AlbumTrack1 - link.mp3" "C:\Other folder\AlbumTrack1.mp3"
Last Edit: April 25, 2025, 08:22:59 PM by Pickles7853
