Author Topic: hotkeys for tabs  (Read 188 times)
serega
hi, I have a question, how to use hotkeys to move between tabs?
It's not in the settings.
But I found the hotkey "control + tab" myself, it goes to the tab on the right, good.
But the main question, what hotkey responds to going to the tab on the left?
Please help me  :(  :(  :(
voodoopunk
You found control + tab by yourself, but never thought to try control + shift + tab?
EDIT: Never checked to see if this worked in Musicbee, it works in Firefox... so just assumed... I have no tabs in Musicbee.
Black Flag - The First Four Years
serega
Yes, thank you very much, you wrote me a reply! Everything works!!! I am very grateful!
There is no hotkey to go to a specific tab.
CTRL+TAB cycles through the tabs from left to right.
CTRL-SHIFT+TAB cycles through the tabs from right to left.
serega
thanks bro, I needed this.
tjinc
You can configure hotkeys to go to specific tabs (tabs 1 through to 9 left to right).
Edit Preferences > Hotkeys > General: Goto Tab n
ACK!!! Where did that come from?  :-0
