Hello everyone, new user here.
This is my second day using this great app and yesterday i had no issues like today.
What i want to achieve is playing songs in a custom way, bigger file size first, and this worked fine yesterday, i would use my custom sort by size, then update play order and pufff, all good.
Today the update play order does nothing, i sort them via menu or via the columns directly, i do see the list sorted as i want, but the left side numbers are wrong and they don't change when i use update play order.
Hope you can help me, thank you.
