Author Topic: Question about missing playcount section  (Read 180 times)
Vico
In a previous (UWP) installation i had, when i selected an album it would show an additional column on the right (in the image below its where the yellow rectangle is) with some information about playcounts of the tracks of that selected album (or in case of an artist, for each one).
I wasn't able to replicate this on my newest installation (non-UWP), if you understood what i mean, how i could add it back?
Thanks in advance!
I'm not sure that I understand all that you said, but:
If it's about the Album and Tracks view, set it to 'detailed list' instead of 'compact grid'.
That should allow you to specify fields. (such as play count)
What is a UWP installation of MB? I don't think that's a thing.
I am guessing he is talking about the 'Store' version. (burn that one with fire)
Universal Windows Platform
Yes, probably the Store version.
Vico
Exactly, sorry for not being clear on the OP.
Didn't find the option here yet. But thanks for the tip.
EDIT: Okay, i think i found the screen i wanted to mean. is this one of this image i found in another topic on the forums:
EDIT2: The issue was just a matter that i was adding the tabs (Artist, Featuring Artist) based on the Music item and not Music Explorer one:
I've noticed that while i can add multiple tabs based on 'Music', adding multiple 'Music Explorer' causes what i can call "redundancy", i mean any change made in one tab ends up going to another of the same type.
Last Edit: March 21, 2025, 01:44:12 AM by Vico
