Author Topic: Need help with Functions  (Read 188 times)
cereal_eater
Hello musicbee community,
using a virtual tag, I'd like to display Album [Mediatype Albumtype Releasetype], but not all tag fields have a value.
With this code
<Album> [$Trim($IsNull(<Mediatype>,,<Mediatype>" ")$IsNull(<Albumtype>,,<Albumtype>" ")$IsNull(<Releasetype>,,<Releasetype>" "))]
a space and the square brackets are still visible, when Mediatype, Albumtype and Releasetype are empty. I couldn't find a way to hide them in that case.
Has anyone an idea how to only display only Album, when the three tag fields are empty?
Pickles7853
I haven't tested it, but from just looking at it this might work...
<Album> $IsNull(<Mediatype><Albumtype><Releasetype>,,[$Trim($IsNull(<Mediatype>,,<Mediatype>" ")$IsNull(<Albumtype>,,<Albumtype>" ")$IsNull(<Releasetype>,,<Releasetype>" "))])
If not you could use $And's
cereal_eater
Thanks a lot Pickles7853,
that worked, but left a space after Album if the three tag fields had no value. I tweaked your code to
<Album>$IsNull(<Mediatype><Albumtype><Releasetype>,," ["$Trim($IsNull(<Mediatype>,,<Mediatype>" ")$IsNull(<Albumtype>,,<Albumtype>" ")$IsNull(<Releasetype>,,<Releasetype>" "))])
and now everything is great.  :)
P.S.: I think, that group intelligence is superior to AI, which failed to provide a solution here.
