$Upper(<.ext>) <Sample Rate>, <Bitrate>, <Channels>, <Time>
$Upper(<.Ext>)" "$If(<Bit Depth>>16,<Bit Depth>" bit, ",)<Sample Rate>", "<Bitrate>$IsNull(<Encoding Quality>,,"( "<Encoding Quality>"), ")<Channels>", "<Time>,)
