Author Topic: [Linux] Album covers not appearing after restarting  (Read 1916 times)
venusor
Hey all, I got MusicBee working in Linux (Ubuntu 22.04) with Wine after some tinkering, and am starting a fresh library. When I scan a folder, music is added and I can see the album artwork in "Album Covers" view. However, when I restart MusicBee, I see "No Cover Art" in place of the album artwork. What's frustrating is when playing a track, the album cover is shown in the bottom right, and each track clearly has album art when going into the properties of the track.
I also noticed that sometimes if I Ctrl+scroll in and out really quickly, I briefly see some of the album covers before they go back to the gray "No Cover Art". I chmod 777'd an entire album folder to confirm it isn't a file permission issue. Before I chalk this up to some weird issue with Wine/Linux, what else could I try?
When adding an album (Jar of Flies)
After restarting (album cover doesn't show for album, but does for current track)
Last Edit: September 23, 2022, 03:52:22 PM by venusor
  • Heal The World
Hi venusor, welcome to the forum.
This probably won't fix it, but you can try resetting the artwork cache and rescanning the music files in Tools > Advanced.
If that doesn't work, you can try some of the other suggestions mentioned in the following threads:
If that won't do it as well, then it's probably a Linux issue as you suspect.
https://getmusicbee.com/forum/index.php?topic=27758.0
https://getmusicbee.com/forum/index.php?topic=25758.0
https://getmusicbee.com/forum/index.php?topic=24254.0
Strength and Honour (2025)
vincent kars
My guess work
Media players when creating a new library starts scanning the audio files.
Likewise importing new files.
As scanning audio files is very time consuming, all tags are stored in a database for fast retrieval.
Likewise album art is stored in a specific directory
In my case C:\Users\vince\AppData\Local\MusicBee\InternalCache
As this is typical Win, check where they are stored on Linux. Maybe the path is simply wrong or missing hence if you restart the album art won't be retrieved.
venusor
My guess work
I think you are onto something here. My cache is in: ~/.wine/drive_c/users/venus/AppData/Local/MusicBee/InternalCache/AlbumCovers
This is essentially the same as yours, but Wine's way of tricking Windows programs to think that there's a C drive. I noticed when I clear the contents of this directory, and re-launch MusicBee, it is the same effect as when I just added the albums, it appears. But now, when I try scrolling down in my albums list, and scrolling back up, the album covers disappear again. It definitely seems related to the cache, as if it displays the cover when it has to write to the InternalCache, but when it's no longer needed it can't see it anymore.
I thought this would be a Linux permissions issue but I chmod 777'd the entire directory and still no luck.
vincent kars
If it is a matter of Musicbee/Wine not able to find the cache, maybe this one is of use as it is about using the cache at another location.
https://getmusicbee.com/forum/index.php?topic=19555.msg116994#msg116994
baanan
I'm also having this exact problem running MusicBee with Bottles on Pop-OS.
I've tried linking the cache folder to a different location, but it didn't help.
Is there any way to just disable caching? I feel like that would be a good quick solution before it gets fixed
Last Edit: January 30, 2023, 06:41:26 AM by ThatEpicBanana
baanan
Update: I switched to a traditional wine install and that fixed it along with a bunch of other issues I was having (such as the automatic bottom track panel colors)
bit
hey, I'm having this exact issue using wine staging 9.15. Did you ever get this resolved?
Hayden
  • Very bitey~ <3
I started encountering this a while ago, just randomly (post here), and I'm honestly not sure what could have caused it.
I didn't make any changes to my wine prefix (I do have a dedicated prefix for MusicBee) or my Wine install since I started using it. I'm not on staging, and the only change that was made was updating to 10.0 at the start of the year (though I started encountering this before this update)
The only thing that really happened was I was converting all of my WMA tracks to Flac since I could't get WMA playback work, something happened at that point, and now no album art loads at all in the main view.
I have a hard time believing it's just a Linux issue, because it was working perfectly fine at first, but then something changed and it suddenly just wasn't working after that, and I have no idea what could have triggered it.
I guess some other info, I use EndeavourOS with the 6.13.1 Arch kernel and KDE Plasma 6.2.5, and I use the Wine 10.0-1 main package from multilib and a 32-bit prefix for MusicBee.
This is pretty much the only problem I've encountered with MusicBee on Linux (aside from no global hotkeys or media integration but that's more a Wine problem than anything else) so I'm a little confused at this obscure issue.
Your local gay 'vern~
