Author Topic: Set 2 different folders in Musicbee  (Read 170 times)
Arylic67
Hi, I have 2 folders, one where there are flacs ripped from cds and another that contains LPs flacs ripped from LPs. I shared the cds folder and musicbee sees it. How can I set the LPs folder too? thanks
  • Heal The World
Are you using a network drive?
Are you asking how to add the LPs folder to your monitored folders?
Are you asking how to add that folder to your library?
It's not clear at the moment what you're looking to do. https://musicbee.fandom.com/wiki/Getting_Started
Strength and Honour (2025)
