Author Topic: Synchronise adds songs to my phone it shouldn't  (Read 776 times)
Arpe
Synchronising music to my phone, Musicbee keeps adding 3 songs that I don't want. I am not syncing all music, I have a list of folders I'm syncing (about 290 out of 301), the folder of songs I don't want is definitely not ticked, if it was all those songs would sync, but only 3 do.
Here is my list showing "The Beach Boys" unticked-
Here are the 3 songs that get copied, this is a snip from the synchronise list-
Any ideas?
Have you looked within the other folders to see if those three songs may be present?
voodoopunk
It's what I was going to suggest, maybe they're part of a compilation?
Or just misplaced.
Black Flag - The First Four Years
Arpe
on a playlist you are syncing?
No, just my music, where some folders are not ticked, such as The Beach Boys.
No it's just the ones from the unticked folder. And they are coming through onto the phone's SD card in the folder structure that is not ticked. (So I only have one copy of Good Vibrations, in the 20 Golden Greats folder, and that's where it comes through to on the SD card.
Last Edit: February 01, 2025, 01:58:26 AM by Arpe
BoringName
Make sure "synchronise music" is unticked otherwise it will ignore your folder selections and just sync everything.
BoringName
Are the beach boys songs in any of those 5 playlists you have ticked?
Arpe
Ah ha! That'll be it, yes they are. Thank you.
Sorry to Steven, I didn't realise exactly what he was asking the first time!  :-[
