Author Topic: ScrobblerBrainz: a plug-in to scrobble tracks to ListenBrainz  (Read 38971 times)
thisisfc
Tried everything, disabled then enabled, uninstalled, even reset my token lol and still... nothing. Shame cause this worked pretty smoothly before.
ETA: Today, for some reason, it's working again? lol
It's not related to ListenBrainz at all.
The plugin is triggered when "NotificationType.PlayCountersChanged" is emitted from MusicBee's side and the play count of a track increases.
But sometimes MusicBee stops emitting the PlayCountersChanged thing, so the plugin doesn't do anything.
Sometimes it's even triggered lots of times in a row if you change songs too fast.
Stopped working for me a few days ago, but I'm sure it'll work again after in a few days. Or after changing whatever in Musicbee's settings.
ThY
Stopped working for me yesterday while listening to music, and after 20ish songs perfectly scrobbled.
I wasn't touching at all to Muscibee settings, just listening.
Don't understand why it happened suddenly :/
ThY
Ok i found that not all my files weren't scrobbling.
I went to the tag inspector of those bad files and removed every Musicbrainz related tags, then it solved the issue and files were scrobbling again.
Give it a try and tell me if that worked for you.
Moren
hi
can somebody please guide me how should i sync music bee to listenbrainz
i followed every steps written in the usage of plugin but i guess it doesn't work
(this is my first time intalling a plugin on music bee)
3lr1c
Hello, up to the 18th of May 2025 this was working for me. Since then no scrobbles.
