Author Topic: Net Framework 4.7.2 issue  (Read 442 times)
RenatoDias
I've installed .net 4.7.2 on a Windows 7 machine, but MusicBee portable refuses to work, saying net framework isn't installed. What should I do?
I downloaded the installer and installed the .net without a hassle;
Restarted the PC;
Tried opening MusicBee, but it stops in the install phase saying .net isn't installed.
tjinc
For MusicBee version 3.5 and later you will need .NET framework 4.8
RenatoDias
The one I got says it requires 4.7.2, not 4.8.
What IS the version of MusicBee that you got?  Help/About.
