Author Topic: Don't forcibly write ENCODER tag when saving any settings in a file  (Read 4444 times)
For the next v3.5 update, the encoder wont be written as a tag but any existing tag for wont be deleted. Its now display only in the tag editor, but if a tag did exist it could be updated/ deleted in the tag inspector
note that its been updated to now use .NET 4.8
if you have any issues please let me know
Last Edit: April 10, 2022, 11:29:13 AM by Steven
SonicRings
What wonderful news to wake up to! Thank you so much, Steven, as always!
There is one issue that doesn't bother me at all, but I think it's worth mentioning in case anyone cares: the encoder seems to be getting cut off due to being too long.
I don't mind whether or not it's fixed, but yeah, that's the only thing I noticed regarding this. Otherwise, great update, and I'm very grateful for this change!
... the encoder seems to be getting cut off due to being too long.
Does the full path appear if you hover the cursor over it?
SonicRings
Doesn't seem like it does. Again, not that I care to see the encoder, but that is the behaviour, yes: there's no way to see the full encoder.
sheldonxp
I would like to get the "forcibly write Encoder tag" option BACK! I actually really liked it, and now that it's been removed, I miss it. How can I go about this without downgrading to an older version of MusicBee?
