Author Topic: "smooth fade when stopping" doesn't appear to be working.  (Read 324 times)
Kaczmaracyck
  • Only listens to the Xenoblade Chronicles OST.
Hi all.
At some point I reset my Musicbee and while I can't remember why I'd do such a thing I've lost somethin I quite enjoyed in the transition, and that was the "smooth fade when stopping feature." You might say "but you obviously know what it is, so just enable it" and well I have done that and yet it just doesn't seem to work. It sounds identical regardless if it's on or off (yes I'm clicking apply in between) so I'm just sorta at a loss. It just seems to be broken. Other things in the "sound effects" section seems to work okay though, so it's not like my options are read only or anything.
Pretty confused. Any input?
Kaczmaracyck
