Author Topic: <Artwork> field in virtual tags  (Read 5465 times)
  • MB Version: 3.6.9255 P
<Artwork> is available from the field selector in virtual tags creator.
Should the value returned ever be anything besides "Unknown Artwork" ?
Maybe something like "Cover", "folder", "Embedded" or "Linked" ?
(originally posted on Questions board)
_______________________________________________________
Could the <Artwork> field in virtual tags be enabled to provide feedback on the MIME type of artwork, please?
A quick google of the bass library API says it can return the apic code for the picture type and even "-->" for the MIME type to show its a link rather than embedded artwork.
Last Edit: April 25, 2017, 11:58:37 PM by Bee-liever
bummer  :(
I was hoping it was reading if MIME type file was attached and returned the picture type eg. Cover (front) or even just Y/N or T/ F so you could check for embedded artwork.
vzell
as vzell has +1'd this, could a moderator move this thread to the wishlist section, please
alec.tron
If I understand this correctly, then this is similar to this, or rather would enable something like this (?): https://getmusicbee.com/forum/index.php?topic=21265.0
In which case +1 from me as well.
c.
Last Edit: April 26, 2017, 01:24:08 AM by alec.tron
altered to a wishlist request
P.S. thanks for the moving, phred
No problem, Bee-liever.  :-)
Dizza17
Very old Wishlist but after reading a few other posts asking for similar functionality, I’m going to give this a +1
When the rich wage war, it’s the poor who suffer.
https://getmusicbee.com/patches/MusicBee36_Patched.zip
I have added a new read-only field "Artwork Location" that shows "Embedded" or the filename for the primary picture only
uncleremus
Hi Steven, thanks for adding this field. Sometimes it returns only "Y". Cannot figure out when or why that happens...
