I have this in \Appdata\Roaming\
You can see twice ASRpresets folder. The first one is old (31/03/2025), I guess this one can be deleted.
Also in the Plugins folders, there is the 'ru' subfolder. Is that the two letter folder you want me to delete?
Which other folders should I delete?
There's also an \Appdata\Local\Musicbee folder but there are no plugin subfolders.
Last, there's \Program Files (x86)\MusicBee\Plugins but this one does only contains MB related Images and artwork folders.
2 "ASR Presets" folders are normal. leave them as is. though you can safely delete "Plugins\ASR Presets" folder if you want, but it will recreated on the next plugin update, anyway.
yes, "ru" is the one of the locale folders i meant. if you find other locale folders like "fr", "de", "pl", etc. delete them too. (from "Plugins" folder(s))
