Hi there,
I'm using the German version of MusicBee and today a strange error occured to my PC for the first time.
When trying to open up my 20.000+ tracks playlist, the list is just empty and there is a message on the top of the screen, reading
No access to C:\...\playlist.mbpWhat happened before is that Partition C ran out of free space (which happens from time to time) and maybe the playlist file was damaged by that.
I also have the log entry here:
26.07.2024 17:22:07 - load playlist=C:\Users\...\Music\MusicBee\Playlists\playlist.mbp: Über das Ende des Datenstroms hinaus kann nicht gelesen werden.
26.07.2024 17:22:07 - 10.0.19045.0 - 3.3.7261.33657D - System.IO.EndOfStreamException: Über das Ende des Datenstroms hinaus kann nicht gelesen werden.
bei System.IO.BinaryReader.ReadString()
bei #=z9NkQJMk6wdGip_YybpQBgJI=.#=ztLCN4hwD_W_9(Stream #=zv7qStKY=, List`1 #=zT1jd8mI=, #=z$u8CB0g= #=zzeb8uUM=)
bei #=z9NkQJMk6wdGip_YybpQBgJI=.#=zR7V0sgXEgoFw(#=z$u8CB0g= #=zzeb8uUM=)
bei #=z9NkQJMk6wdGip_YybpQBgJI=.#=znRsazQ4=(TriState #=z3b2CyQIPrLem)
bei #=zlpWM7vlOZnRzBxwVf7prPpFOpng8.#=qKZgaxkmd$V2Cl1StbyMv$j9qvk7p8EBkMAV65xHkR_g=._Lambda$__0()
Über das Ende des Datenstroms hinaus kann nicht gelesen werden translates to
Reading beyond the end of the data stream is not possible.
Any idea on how to fix this? I don't want to make up a new list manually
Thank you for any help provided!
