Version 3.5.8698
One of the artists is listed twice with one of the entries being blank.
The correct entry further down the list:
This also happens in library statistics:
The artist displays correctly in the tag editor and track information.
Exiftool output for one of the files:
ExifTool Version Number : 12.67
File Name : 01 - Seishun Complex.flac
Directory : .
File Size : 48 MB
File Modification Date/Time : 2024:07:21 00:23:51-05:00
File Access Date/Time : 2024:07:21 00:24:18-05:00
File Creation Date/Time : 2024:07:21 00:23:51-05:00
File Permissions : -rw-rw-rw-
File Type : FLAC
File Type Extension : flac
MIME Type : audio/flac
Block Size Min : 4096
Block Size Max : 4096
Frame Size Min : 16
Frame Size Max : 22770
Sample Rate : 48000
Channels : 2
Bits Per Sample : 24
Total Samples : 9774080
MD5 Signature : dd723ac6be57c383dd03a092de4e39e1
Vendor : reference libFLAC 1.3.1 20141125
Tag 07f 42305-3c 75-529c-ba 48-09435e 88980d:
Tag 45b 1d 925-1448-5784-b 4da-b 89901050a 13: 10006001
Tag 50dbf 5a 2-f 864-5c 17-be 00-c 36dfd 3df 7b 4:
Tag 8e 90f 26b-372a-5c 8c-bb 05-1ec 0f 36ee 60c: SVWC70613B00Z_48-S01001
Tag 93a 74bea-ce 97-5571-a 56a-c 5084dba 9873: JPE302200934
Be 242671-3d 48-5ac 8-b 762-7d 2db 4f 584b 8: 22824922
Copyright : (P) 2022 Aniplex Inc.
Ff 8ca 75f-2d 68-52eb-85d 6-1580486025a 4: 95329905
Genrenumber :
Title : Seishun Complex
Composer : otoha
Artistsort : Kessoku Band
Display Artist : Kessoku Band
Performer :
Album : Kessoku Band
Albumartist : Kessoku Band
Discnumber : 1
Date : 2022-12-25
Organization : JASRAC / Aniplex Inc.
Track Number : 1
Picture Type : Front Cover
Picture MIME Type : image/jpeg
Picture Description :
Picture Width : 1000
Picture Height : 1000
Picture Bits Per Pixel : 24
Picture Indexed Colors : 0
Picture Length : 107892
Picture : (Binary data 107892 bytes, use -b option to extract)
Duration : 0:03:24
