A little context please. What are you doing when you get the error? And it's helpful to paste the entire error message rather than just one line.
Sounds like the element in question is a skin that has an incorrect value. As the error message says, it has to be threes digits no greater than 255.
Try with a different skin and if that works, correct the skin that's causing the error.
