Not sure this is particularly important but thought I would report - identified in
this postMusicBee 3.6.8869 P
With Folder Browser and Navigator both displayed in the same tab, switching from a selected folder to the Music node does not refresh the contents of the main panel (it retains the contents of the last folder selected).
Notes:
If Library filters are configured and selected, then the main panel contents are refreshed as expected.
If any other node is selected first and then the Music node then the main panel contents are refreshed as expected.
If using the Computer node (instead of the Folder Browser), then the main panel contents are refreshed as expected - I imagine that most people use this, or would be happy to use this, instead.
