Author Topic: Differences in tag display and behavior between different types of panels  (Read 138 times)
eobet
I'm beginning to explore the possibilities with MusicBee customization and a few thing confuse me:
In the below picture:
1. The artist name in the track information panel has a checkbox to automatically link to a list of all tracks by that artist, but I can't find a similar option for the main player controls along the bottom. Is there one?
2. In the track properties of the track information panel, you can see that it says "MP3", but in the main player controls when I add the "kind" tag, it says "MPEG audio file" and I could not find a tag which said MP3. Did I miss one?
3. Are there formatting tags apart from color and font? Like, centered, right-adjust or just some tab spacing?
  • Heal The World
#1 No, there isn't one. It's not supported in the player panel.
#2 Look for extension <.Ext>
#3 Not exactly, but you might want to check out Edit > Edit Preferences > Tags (2) > Configure Fields...
The source code to any of my contributions is available on the same download link as the add-ons
