Author Topic: Playlist mixer Any Field Null problem  (Read 436 times)
sarashaw
Just updated to 3.6.8800 and some playlist mixers no longer work.
Problem is that they have criterion:  "Any Field....Has a Value"
That translates to "is not null" in the criteria list display
(btw I am selecting from sublists rather than creating futile entries!)
If I change "any field"  to anything else - say "Title has a value" then this works fine.  Likewise specifying a value for any field then returns an appropriate list.
This is a problem for me selecting from other playlists but to check it also doesn't work if I select the top radio box and my entire music library...
Guess a quote mark got knocked off in the code or something?
Thx
