Author Topic: Tried to remove album  (Read 351 times)
Jenn28
MusicBee v3.5.8447.35843Store (Win10.0), 9 Jan 2024 11:55:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at #=zW4Xb63bx5Mj6PflfmTaiXdbcsh6cBUVmbQ==.#=zW$R_00Bj10Tc(IList`1 #=zRUQzmHPnj6ln, Int32 #=zsnQcqEZzzPoD, Int32[] #=z1I2Lwz7a7LcY, HashSet`1 #=zTfgSRBC26_CL, Int32 #=zEv7m060=)
   at #=zW4Xb63bx5Mj6PflfmTaiXdbcsh6cBUVmbQ==.#=zfIyyQMJ17pAf(IList`1 #=zRUQzmHPnj6ln, Int32[] #=zTfgSRBC26_CL)
   at #=zRSmWnDm6ujKkADp0na7viWE=.#=zfIyyQMJ17pAf(List`1 #=zRUQzmHPnj6ln, Int32[] #=zTfgSRBC26_CL)
   at #=zXL0Fw5LmrPoZtt6M3ZuxQezE86EWuLiiB2dGwJU=.#=zZC1qtsy3tcZQCWlLOfx_F_I=.#=zLzdUjYL93gWUSkfrIJQEQAMfwcbp.#=zPP64TniIck7q(List`1 #=ztTiYibs=, Boolean #=zW2qKmSVHPRy0)
   at #=zP4IbwufPC8$lFvJG3j$s2i8=.#=zqzujmaISsVSd.#=z7vxTz9fEf6Vh.#=zLCyp7IME6evA(Object #=zNJBP6jk=, EventArgs #=zmmOoBdU=)
Exactly what where you doing when this error occurred? A step by step might be helpful.
Since you're using the Store version of MB, even if the issue is fixable, a new release won't be issue soon. I suggest using the Portable version and install it in a directory outside of Windows control. Something like x:\MusicBee. Or you can use the Installer version. Both of which are exactly the same and have frequent updates and bug fixes.
