Author Topic: Albums not being fully updated after tagging  (Read 727 times)
ayra19th
So i just transferred my tags music library to another disk and everything was fine at first, but now whenever i edit an album it keeps showing up as an UNKNOWN ALBUM folder which wasn't the case before.
https://imgur.com/ChNMrhd
https://imgur.com/NgDm8vA
Also when i update an album and tags when there's two of them it doesn't update i always edit my tags in musicbee and this has never been an issu before any help will be appreciated
If they are .wav files you might need to update to the latest MB version and re-edit the tags
ayra19th
I do have latest version this only started happenning a while ago after i had moved everything.
can you send a link to one of the files and also check the error log for any errors around the time you save the file (help/ support/ view error log)
ayra19th
I download my files from here and theyr're all mp3 https://free-mp3-download.net/download.php?id=1629080302&q=ZXJpY2RvYQ==
And here's the error log https://drive.google.com/file/d/1ngoO-_hAYpvcjWFW4S8Bhkc7akyLuB2G/view?usp=sharing
Last Edit: December 12, 2023, 03:00:58 PM by ayra19th
all i can say from the error log is your plugins are throwing a lot of errors so it might be worth disabling them and then restarting MB to see if it helps
