Author Topic: Theatre Mode background (Rdio Style)  (Read 1684 times)
StygianSaviour
Well, i'm not sure if it's correct to ask it here, but i have a trouble with Rdio Style in Theatre Mode. The background seems to be in a poor quality. I cannot customize Theater Mode in settings, button doesn't work. So, which file do i need to change by myself to fix this? I found "Rdio Style (embedded).xml" and "Rdio Style.xml" in two different folders, what's the difference between them?
https://i.imgur.com/Okca5Uj.png
You can see a lot of ladders and squares here.
Jeremy Meunier
I'm replying to this dead post because I have exactly the same problem.
Is there a way to increase the blur of the background image and/or avoid resizing it (my artwork is 1500 x 1500) ?
Thanks,
Jeremy.
Please post your report/issue/question on the thread for the Theatre Mode in question.
https://getmusicbee.com/forum/index.php?topic=32466.msg178512#msg178512
Note that the author hasn't been on the forum in more than a year and a half.
I'm locking this thread.
Last Edit: October 07, 2023, 06:25:45 PM by phred
