Author Topic: "read only files detected"  (Read 564 times)
jmputt
i'm new to musicbee, so please be gentle.  i've searched the forum for an answer but cannot find one for the most current version of musicbee:  i imported new music; none of the metadata was attached.  i want to edit, but i can't because "read only files detected."  is there a work-around for this?
select the folder, where your music files are stored (e.g. c:\users\<your username>\music), right-click on the folder, select "properties", uncheck "read-only" (there will be 3 states of checkbox, you need the "empty/fully unchecked" state). click "ok", confirm resetting read-only attributes.
Expanding on what boroda said, this is done with a Windows file explorer and NOT within MB.
EDIT: Typo
Last Edit: June 30, 2023, 09:02:07 PM by phred
