Author Topic: drag & drop bug (?): moving files instead of copying  (Read 4808 times)
Have you tried dragging while holding down the CONTROL key? As stated a couple of times in this thread.
coolguy8
That's not my problem, I'm not trying to move or copy the file. It's very easy to accidentally drag and drop a track from MusicBee to, say, the desktop (as I described in my original post.)
The purpose in being able to switch the copy and move functions for drag & drop is to avoid moving a file out of place in the file system without meaning to.
Actually, now that I think about it an option to simply lock or disallow drag & drop from MusicBee to outside the application would also accomplish this.
coolguy8
Here's a visual explaining what I mean...
I keep MusicBee in a smaller window, I made a quick movement to drag the window and dragged the music track to the desktop by mistake. Now it has moved from it's original place on my hard drive, so I have to dig through the file explorer and re-place it into its correct spot.
I realize the scenario is kind of dumb, but it has happened more than once and I think the option to lock the ability to drag & drop files from MusicBee to elsewhere in the file system (rather than switch copy/move functionality as I previously suggested) is a reasonable request.
