Author Topic: Missing Close button under Expanded Artwork View  (Read 1684 times)
SeriouslyImNotaBot
The X button is missing from under the expanded view. I use MusicBee on two different devices, one of them works perfectly fine. But I just realized recently that the (X) button is missing from my main device that I use more regularly. It's generally very inconvenient since I have to click on an empty space which could be difficult if the artist has a lot of albums like the one above. I know you could use the escape button to go back but that's another story.
Here's a screenshot from my other device that works perfectly fine. As far as I know, both devices use the same exact settings and all.
Any help and response would be much appreciated, thank you in advance!
Last Edit: November 16, 2021, 06:15:06 AM by SeriouslyImNotaBot
In the expanded panel settings, re-enable artwork display then set the picture to show on the left and then untick the artwork display.
I guess it is a bug so i will fix it
It also appears that there's no close button (X} when the artwork is on the right side.
