Author Topic: Changing Art Work On Artist Left Panel  (Read 1896 times)
downupstair
I want to change the image associated with an artist in the left panel that shows the "Album Artist."  I have tried right clicking on an image and copying it - then right clicking on the image on the left panel and choosing "Past Artwork," but it never works.  No matter how many times I try, the image does not change - reloading the program does not work.
So ... there has to be an easy way to change this image.  How?
Thanks.
Hi, welcome to the forum!
You've found the correct way, so the question becomes why it isn't working. If you look at your error log (Help > About), are there any errors that look like they might be related?
Do you have "show artist picture" ticked when you click the "Album Artist" button in the left panel?
And are you using the latest version from the downloads page?
Roby
It doesn't work for me either. Ver. 3.4.76250 P and "ShowArtist Picture" selected. The "Paste Artwork" menu item cannot be selected (it is light gray).
