Author Topic: HandleClick NullReferenceException on multiple actions  (Read 1089 times)
DevilBlackDeath
Hello,
I'm new to the forum but have been using MusicBee for years now. Just want to add before reporting my bug that it's the best music software out there and it lets you handle your music library in amazing ways.
So my bug is not a big one. Whenever I create a playlist, analyse music, auto-tag by album and actions like these, I get this error (likely not always with the same random characters, but it's always in the same vein) :
MusicBee v3.3.7367.38620D  (Win10.0), 12 Mar 2020 11:37:
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zH6w$9kE=.#=zmI807nKDVUeRC1reKHl1b6Y=(String[][] #=zg6BFEgAPwPO3)
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zizd53H1Kk$8e(IList`1 #=zwl3UI6s=, TagCode #=z1VUn09w=, Boolean #=z8LwBDv0bkZ7B)
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=z7nUA$PMMuk7v(String #=zumsg5SI=, List`1 #=zvHGv1A$k5XdK, Boolean #=z3sxbwE4=)
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zo3JS0rNL4vf$4b3cRQ==(String #=zcc8Jzz4=, List`1 #=zkvN9$m7QiXHD, Boolean #=z3sxbwE4=)
   at #=zADbnadLxl1TKH02_Qzso3yQ4IyJJ.#=zbCbCmL8=.#=z8qGFd8A=(ApplicationCommand #=zYPDjVpU=, Object #=zV8gvbZE=, IList`1 #=zwl3UI6s=)
   at #=z4EgwUhxpom0N1K03jT6eNkk=.OnClick(EventArgs #=zHB5no$s=)
It doesn't result in the cancellation of the action that has always been, until now, completed successfully. It just shows up at the end of it !
As the log shows I'm already running the latest version.
Thanks in advance and thanks again for all the great work.
can you send me a link to your settings file (help/ support/ view settings) and a screenshot of the application just before you trigger the error
DevilBlackDeath
Hey ! Here is my settings file :
https://jpst.it/23owu
It's almost exclusively imported settings from my previous installs (my settings have traveled through at least 2 or 3 computers and even more clean Windows install  :P )
As for the screenshot it's hard as it's mostly the standard UI and it only happens when I try those actions (one of which just being right click a song and add it to a playlist). I'll try to do that last one and make a screenshot of it.
Hey, here you go for the picture, this is one of the action that would trigger that kind of error, followed by the exact error message I got from clicking it :
https://imgur.com/a/tzCfRDP
MusicBee v3.3.7367.38620D  (Win10.0), 12 Mar 2020 13:09:
   at #=zziapYCHkKIL0B5EplaYmmhGl87_u.#=zD61boNyaDiPe(#=zKG9L0hExTpfpzuHiLIrDo50= #=zIKh4fYU=, List`1 #=zwl3UI6s=, List`1 #=zeIcKakd9nNCL)
   at #=z5aHGmCYdx9Nx8_fjNthAzPXKlrsa.#=zmB5BdgaiC08Gr5$vMg==(Object #=z4OVDJ6s=, EventArgs #=zHB5no$s=)
Last Edit: March 12, 2020, 01:10:40 PM by DevilBlackDeath
Your settings file is a bit wonky for the column browser and I dont know how it happened other than perhaps some issue with an upgrade from an old MB version.
You need to change this in the settings file (make sure MB is closed at the time)
<NavigatorTrackBrowserPrimaryFilter>59</NavigatorTrackBrowserPrimaryFilter>
<NavigatorTrackBrowserPrimary2Filter>0</NavigatorTrackBrowserPrimary2Filter>
<NavigatorTrackBrowserSecondaryFilter>32</NavigatorTrackBrowserSecondaryFilter>
<NavigatorTrackBrowserTertiaryFilter>30</NavigatorTrackBrowserTertiaryFilter>
to
<NavigatorTrackBrowserPrimary2Filter>32</NavigatorTrackBrowserPrimary2Filter>
<NavigatorTrackBrowserSecondaryFilter>30</NavigatorTrackBrowserSecondaryFilter>
<NavigatorTrackBrowserTertiaryFilter>0</NavigatorTrackBrowserTertiaryFilter>
DevilBlackDeath
Thanks a lot, that worked :) Doesn't seem to trigger the bug anymore !
