Author Topic: Album cover images are diplayed twice or more  (Read 1440 times)
fournier
If Windows 10 taskbar overlaps album cover images, and the images are scrolled up,
then the images are diplayed twice or more.
↓ scroll up
I'm using MusicBee 3.3.7240.
presumably because they are linked to the same picture file. You can check the first track of each album in the tag editor/artwork/save to... window
fournier
I checked them. The picture files are embedded in the music file.
I misread your original post and i can reproduce the issue so i will see what can be done
I have addressed this for v3.4 which is not available in beta just yet
fournier
