Author Topic: How to filter exact duplicates from auto-playlists but not from different albums  (Read 795 times)
Maith
I have an auto-playlist. The sources are two different playlists.
Some tracks are in both lists and I want to filter them in my new playlist.
Here is the catch:
I do not want to filter tracks from different albums, I only want to filter the exact same file.
Is that possible?
Thanks
Select the auto-playlist > Edit auto-playlist > remove from playlist only
You can confirm removed tracks by right-clicking on the auto-playlist > edit auto-playlist > click on remove files, which will show you which files have been removed from the select auto-playlist
