Author Topic: Sidebar resizing bug  (Read 1423 times)
While MB's rescanning files, I tried to resize the width of left navigator a bit and got this error:
3.3.6875.19299 - System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at #=zLIaARTp4GQq$YlNS1wx9x6g=.#=zdSDoN6qzr9kd.#=zEl_pMmRjIMbT()
   at #=zLIaARTp4GQq$YlNS1wx9x6g=.#=zdSDoN6qzr9kd.#=zm8wk2WzsMZrp()
   at #=zLIaARTp4GQq$YlNS1wx9x6g=.#=zdSDoN6qzr9kd.#=zGvA7o2A=(Boolean #=zmALvjGJ16h5t)
   at #=zLIaARTp4GQq$YlNS1wx9x6g=.#=zdSDoN6qzr9kd.#=zS2RJ8Wa0Qeoq(#=zl3yJEf4WGZBSB46QIIynPR4= #=zGGWQbTI=)
   at #=zLIaARTp4GQq$YlNS1wx9x6g=.#=zdSDoN6qzr9kd.#=zXpZD1ksUKW96EYIuJWsEj1Ep3Y20(Boolean #=z2Npj1$C4SoXD)
   at #=zLIaARTp4GQq$YlNS1wx9x6g=.#=zUgk4qULE$MvF()
   at #=zNHqj_OF90KNJWJD7Qw2fwxzP39Pk.#=zt05WiMpHwh3M.#=zUgk4qULE$MvF()
   at #=ziPHleZ_u48UMqdnb_YM91vM=.OnLayout(LayoutEventArgs #=zVK_1aZA=)
   at System.Windows.Forms.Control.PerformLayout(LayoutEventArgs args)
   at System.Windows.Forms.Control.System.Windows.Forms.Layout.IArrangedElement.PerformLayout(IArrangedElement affectedElement, String affectedProperty)
   at System.Windows.Forms.Control.OnResize(EventArgs e)
   at System.Windows.Forms.Control.OnSizeChanged(EventArgs e)
   at System.Windows.Forms.Control.UpdateBounds(Int32 x, Int32 y, Int32 width, Int32 height, Int32 clientWidth, Int32 clientHeight)
   at System.Windows.Forms.Control.UpdateBounds()
   at #=zkaZmsg_Cz3qOCEJZ68rO14s=.WndProc(Message& #=zUqdbsHY=)
Select all files in the main panel and try to resize a sidebar, then it always happens to me.
zkhcohen
thats fixed now:
3.3 has been on version 6870 for the past couple of releases. Is this intentional?
the number auto-increments and is 6877 at present. I am guessing somehow you are not overwriting the files
zkhcohen
thats fixed now:
Ohhh... you renamed the .exe to MusicBee from MusicBee33.
Actually, Steven changed the exe back to MusicBee.exe a few patches ago.
