Author Topic: Device Icons  (Read 9415 times)
Blinghound
Hello all,
I use an Ipod Classic 120gb 6th generation to sync my music, and on the device screen, (pictured below) I was wondering why there is no icon/picture.
Is it possible to change this manually? Should there be one?
Thanks for any advice
i cant see the picture. I know with some people at least the latest generations of devices arent working with MB and i am doubtful they will be supported by MB (the developer of the library i use no longer is supporting it)
Blinghound
Thanks Steven. Everything else works brilliantly - syncing, artwork in coverflow (which some people have problems with), two way playcounts etc etc.
Is it impossible to manually change the picture? Or is this a setting hidden within the library that is used?
can you repost the screenshot so i can see what you have
still cant see any picture - can you?
Blinghound
I can see the image - I even checked the link, but I have reuploaded to a different image host.
